| | | Forums66 Topics128,043 Posts1,055,609 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 28 Junior Member | | Junior Member Joined: Jan 2002 Posts: 28 | Need both upper clam shell hinges for my 45 Burb. I beleive 41-46 are the same and have been told AD years may fit also. | | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | GOOD LUCK! As I recall someone here switched from clamshell to barn doors awhile back, maybe they are still sitting on a set. Did you check the Swap Meet Section above?
Buddy | | | | | Joined: Jan 2002 Posts: 28 Junior Member | | Junior Member Joined: Jan 2002 Posts: 28 | yep, nothing in the swapper | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | If you can post some pictures of the hinges that you want, I will see if a set of AD hinges will work. I may have a usable set of AD hinges. .........g | | | | | Joined: Jan 2002 Posts: 28 Junior Member | | Junior Member Joined: Jan 2002 Posts: 28 | Thanks. I'll try to get some pics this weekend and send to you on Monday. Not really sure there is enought of the hinges left to ID but I'll get what I can........Glade someone out there answered..... | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Grant, I thought that this question was familiar. We already decided that the Art Deco and the advance design hinges were not interchangeble. Go ahead and post some pictures of what you have and I will help you find some. ......g Previous post Brad\'s 41-46 home page | | |
