7 members (52Carl, joe apple, Otto Skorzeny, 55shaker, Gray_Ghost, Hush, JW51),
147
Mod | | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | After a lot of chasing around and bidding for 'burb seats, only to be beat by someone willing to pay more, I have found stock appearing seats from a '58 International Travelall. The center seat is 39" overal length including the armrests and the back seat is 48" wide-a little narrower than the gm seat. But the schoolbus type frames with metal backs resemble the gm seats and most important, the price was right! There will need to be some mounting modifications, but nothing serious or difficult. Email me for the photos if you want to see them or if you can post them here.  | | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Sorry, this webhost cannot be used to access these photos. Will work some more on this problem. | | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | | | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Close but no cigar! If you don't want them send them to me  ........g I sent you an email. | | | | | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | Looks like the photos of GM seats I have found , can,t find anything but photos for the 40 chevrolet sub. I could use a set of them. I will email you for info. Bill | | | | | Joined: May 2005 Posts: 5 Junior Member | | Junior Member Joined: May 2005 Posts: 5 | please let me know if you want to get rid of the 48" rear seat. that is all i need to complete my burban. | | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | The overall width of the Travelall rear seat is 52 & 1/4"--the same as the stock gm seat (measured from the outside of the diagonal braces on the ends.) The center seat cushion is 36" wide. The stock gm front seat cushions fit the Travelall center seat frame. The seats will be perfect matches for the original missing stock gm seats once the mounting brackets are fabricated (from half inch steel pipe.) The seats are securely stored in a stovebolt vault, but would gladly be traded for the correct gm seats! By the time I'm ready to powder coat the frames and re-new the cushions, I may find the original seats. If not no one will know the difference once these are detailed.  | | |
