2 members (1955 1 Series, Donf), 327 guests, and 6 robots.
Topics128,160
Posts1,057,054
Members48,463
#244035 10/13/2004 8:04 PM
Anonymous
Unregistered
Anonymous
Unregistered
looking into changing my engine(235)to a 472. what engine do you have or going to install in your suburban or panel. looking for some more ideas. also the albertons grocery chain in this area is selling small metal models of suburbans('47-'53).
tony'n weatherford
#244036 10/13/2004 11:40 PM
Hey Tony, what does the 472 come in? I'm just an old fart and behind times. :confused:
#244037 10/14/2004 12:27 AM
I went with the 350 SBC. Parts are plentiful & cheap. Look here:
http://community.webshots.com/user/pywgn
JS
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
#244038 10/14/2004 12:47 AM
Anonymous
Unregistered
Anonymous
Unregistered
Seon, the 472 and 500 came in the cadillacs
tony'n weatherford
#244039 10/14/2004 1:03 AM
Boy, that is what that thing needs,,a real gas guzzler,,,hey, did you buy that 70?? how about going down to winnsboro on the 23rd,,,,regards..Fred
Redryder pix
My Hotrod
#244040 10/14/2004 1:19 AM
The 472's and 500's are only slightly bigger, and heavier, than smallblock Chevvies. There's a pretty good assortment of hotrod parts for them, too. I'm planning to put a 500/Turbo 400 setup in my 59 Burb one of these days.
#244041 10/14/2004 2:25 AM
Z
Z Offline
i have a cad 500/turbo 400 with an eldlebrock intake in my 64.
#244042 10/14/2004 2:46 AM
I like the big Cadillac and thought about putting one in my Suburban.
My Suburban is a '55 1st GMC. The next model GMC's were available with Pontiac V-8s.
I've often thought it would be fun to install a Pontiac 455 with valve covers with GMC stamped in them. And then I'd tell everyone it was the original motor.
But I've since learned that the valve covers had decals, not embossed logos, so it wouldn't be near as interesting.
I found a good deal, so I bought a 454 and will probably put that in. Someday...
#244043 10/14/2004 3:39 AM
Anonymous
Unregistered
Anonymous
Unregistered
hey fred , what do you mean by gas guzzler if i install a 472, i'm getting 9mpg with the 235 that in there now!
tony'n weatherford grin
#244044 10/14/2004 9:44 PM
I scored a 1987 454 w/ th400 from a wrecked 1 ton. I'm installing on a 69 Nova clip into a 49 burb. Hope to be on the road by spring.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
#244045 10/15/2004 11:02 PM
Moderator
Moderator
Mine currently has a 267 V8 from a '79 or '80 Maliubu or Camaro. It has ring blow-by and valve problems. All I wanna do is junk it. My dream is to put a big block in there. For now I would be happy to find a decent SBC to do a direct swap, and think about a big block when I find a deal on one and tear this thing down for the frame-off rebuild.
My dad had a '68 Caddy with the 472, and that thing would fly! Didn't they have a beefed up version of the TH400? I seem to remember it being called a TH475.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
#244046 10/16/2004 2:01 PM
Hey Tony, thanks for the 472 info. I need to get out of Chevy box because small and big blocks are the only engines I've ever instlled in these old Chevies :rolleyes: . Those Caddy engines should push a Burb down the road with ease.
#244047 10/17/2004 4:11 AM
I towed a 3-axle backhoe trailer from California to Tennessee in 1980 with a 70 Fleetwood, with a 472. Gross weight on the car and trailer was 16,700 pounds, by the truck scales at the Arizona point of entry, where I had to get an over-wide permit. I was moving back home to Nashville, with everything we owned on the trailer, and crammed into my 59 Burb with my wife behind the wheel. 2,500 miles at 5 MPG, (10 on the Burb) but no problems out of either vehicle! Those 472's are tough!
#244048 10/19/2004 11:34 PM
24601
24601
Shoot, Tony -- why stop there? everybody does gas V-8s. They're so yawnsville, dude. Be original! If you want power, slap a 671 Detroit or a Maxidyne in there, man!
That's what I'm waiting for. I wish I had a quarter for every AD truck I've seen with the 350/454/T350 combo in it. Yay. Whatever. So far, no one has sent me any photos of their diesel-equipped AD. My friend and neighbor, Mike Boetteler, has a big diesel-equipped Task Force but it doesn't count 'cause it came from the factory that way.
Torque? Think diesel! grin C'mon, one of these days, somebody is going to impress me! :p
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
#244049 10/20/2004 1:17 AM
Well, John, you might get your wish one of these days! (Gotta be careful about wishes, sometimes they come true!) I've got 5 120-HP Cummins turbo diesels socked away, take-outs from UPS trucks, and one of them is likely to end up in a stovebolt one of these days. They have the same bellhousing bolt pattern as the smallblock V-8's, or the 230/250/292 6-cylinders. The ones that are on the engines right now are the hydraulic clutch types, with the slave cylinder/throwout fork on the passenger's side. UPS used these engines interchangeably with 292's and Ford 300 I-6's. They're heavier than a 292, and a little longer, I think, but not too big to fit under an AD hood. I've got a couple of New Process 235 transmissions that will fit the bellhousings, or a Turbo 350 or 400 could be adapted, I believe. How would that work out for an unusual early-50's Stovebolt?
#244050 10/20/2004 1:21 AM
Anonymous
Unregistered
Anonymous
Unregistered
hey john, there is a gentleman in my aera that has an olds deisel in his '53 5 window. he's had some good service out of it. if i ever get a chance to put a nail in his foot, i'll get some pictures of this truck.
tony'n weatherford
#244051 10/20/2004 1:36 PM
I'm looking for a late model 350. I want the computer and fuel injection and everything. My Dad has a 95 chevy truck that has the same and gets 24 mpg. My Burb is destined to be a road dog so good mileage is a must.
Of course a higher speed rear axle will also have to be in this picture.
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
