9 members (Nhluvstruck, Peggy M, Otto Skorzeny, MickeyP, 55shaker, Gdads51, VEW, 50Chevy3100, 1 invisible),
62
Mod | | | Forums66 Topics128,090 Posts1,056,015 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | Yep, Looks like an axle seal and a cover gasket also. You will most likely have to change the cover gasket anyway to change out the seal.
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | An overfilled diff. will cause leaking seals also. Add fluid to about 14mm (9/16") below the fill plug.I've seen this concern all too often.
JS | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | How hard is this seal to change? Can I get the parts tonight at my laps? | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | May very well be able to get the seal locally tonight. CHanging the rear cover gasket will let you put fresh gear oil in the differential as well, always good to change once in awhile (2 or 3 years) OH,, be ware of the old gear oil stink Look closely at the plase where the axle seal is suppose to seal, make sure there are no grooves or cuts in the surface. Remove the 4 nuts through the hole in the axle flange and use a chain with a weight if needed attached to one of the lugs on the flange. Use the chain/weight as a whip and the axle should pop right out. BE SURE to not be standing directly in-line with the axle incase it decides to come out quickly and get you  (stand off to the side a little) ALSO, change the shoes, soaked brake linings are not good stopping devices,,, no matter how well you try to clean them. Remove one side at a time so you have a reference as to how they go back together
| | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Where are the 4 nuts in the axle flange? Are they visible in any of the photos on this post? | | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | I went through this drill with my '55 first series. This axle assembly has some "c" clips in the differential housing that will need to be removed. You will not be able to remove the axles until those are off. Then the axles will come out easy, at least mine did. I recommend either a factory shop manual or Motors Chiltons to get the steps right. I think the reason my seals failed was due to the axle vent being plugged so there was no relief when the fluid warmed up. The only place it could go was out the seals. My truck had the open Hotchkiss differential, but if you have a torque tube and have been topping off your tranny, that fluid may have found a path through the okie bushing and seal back to your rear axle seals.  | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | and yes, that is the proper 55-59 rear axle - parts are easily available - rear axle seals - NAPA# 49225 [Federal# 414045]
Bill | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Okie bushing???
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | I forgot you had a task force truck. Forget about the okie bushing and seal that is for a torque tube truck. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | splashoil, i've notice lately that one of my axel seals maybe leaking. will that number for the replacement seal work on my truck? it's a one ton,with a two piece drive shaft and I've already changed the 3rd member to a 4.10.
tony'n weatherford | | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | That was Squeeze who gave the part # for 1/2 ton axle seals, but since you asked, I had this '33-'61 Chevrolet Master Parts catalog hogging space on the kitchen table so: '46-'61 3/4, 1 TON GASKET, rear hub 1/2 axle bolts (2& 3/4 I.D. x 4& 7/16 O.D. Chevrolet part # 3680995 This should work in most parts stores as a cross reference for your axle.  | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Lets pose a hypothetical (hy-pathetic) question. Suppose I wanted to get higher gear ratios from my rear axle. Is it possible to have that done and have the seals replaced at the same time? The old 2 birds with one rusty tool concept. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | The seal replacement will be part of a good re-gearing job. You might consider a later-model axle assembly, however. Rehabbing a 40+ year old part is tougher, and usually more expensive than a transplant, unless you just want to stay original for some reason. Jerry
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You mentioned in another thread you plan to eventually put ifs on your truck. If that is the case you should consider finding a rear end with matching wheel bolt pattern rather than putting money into a 6-bolt rear end. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Someone mentioned using a Dodge Dakota IFS for a conversion a while back. That one's a 6-lug wheel pattern, isn't it? It just might be that somebody's stumbled onto the ideal way to do an IFS conversion and stay with stock-appearing wheels, etc. Jerry
| | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | I would love to replace the rear axle with something about an inch narrower. My tires scrub a little when I'm loaded (like 1000 lbs. of candy) I'm not interested in original. I'm interested in functional. | | |
