1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
Kelly (wife) wanted to go to Sams a few nights ago so I suggested we take the 59 Suburban. She didn't want an adventure she said.....just to go to Sams. I assured her things where different now. The old truck was being forged almost daily into a dependable driver.
OK
So we are driving along on a 2 lane road at night on our way to Sams when I decided to switch the high beams on. Instead of the high beams I got a complete blackout going 40 mph. This was not what I expected and certainly not what Kelly desired. As she firmly gripped anything close I jostled the headlight switch until I finally got the lights back on.
This "short" happened a few other times that night. Anybody have a good idea as to the probable source of the problem? My guess is the switch.
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
Did it only happen when using the high beam switch? If so, I'd suspect the high beam switch. If, on the other hand it was happening when turning the headlights on or off, I'd suspect the light switch. High beam switches, because they are exposed to so much water, dirt, etc. are often the culprit. Also, before spending a lot of time on the switches, check the wiring and wire connections.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
Have you resolved this?
The headlight switch has circuit breaker in it that might have become weak, or maybe you've got upgraded headlights that overcome the circuit breaker.
You may want to use a relay for the headlights, or get a newer headlight switch that can handle more amps.
See new thread-Headlight switch removal
More on Hotrodders
