1 members (Woodcmiami), 72 guests, and 3 robots.
Topics128,031
Posts1,055,433
Members48,422
#243515 04/22/2005 10:38 PM
I'm trying to replace the rivet that holds the vent window at the top of my 59. The rivet goes in from the inside or glass side of the frame and sticks out the top. However, it isn't long enough to run through the rubber into the metal frame. Am I missing something? The shop manual doesn't mention the rivet at all.
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
#243516 04/28/2005 9:20 AM
Junior Member
Junior Member
Are you sure you're using the correct length rivet? They come in various sizes and lengths.
#243517 04/28/2005 1:15 PM
Bought it from fillingstation.com. It's for my year truck.Here is the link if it works. It says it will fit from 51-59.
http://www.parts123.com/PartFrame.a...illingstation/&TITLE=Filling_station
More on Hotrodders
#243518 04/30/2005 12:16 PM
Junior Member
Junior Member
Can you use a probe of some type, and measure the length of the rivet hole? I would use a roll pin punch of the same diameter as the rivet hole. Then you will have your rivet size, and length. I sure hope this helps. I know how frustrating these little delays can be!
