0 members (), 348 guests, and 6 robots.
Topics128,162
Posts1,057,042
Members48,463
#243261 11/12/2004 6:12 PM
I need help on getting this switch out. It needs cleaning badly.
Can't figure out how to get it out. Found the release spring/button for the shaft but need more info.
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
#243262 11/12/2004 7:19 PM
Turn the headlights on (pull the switch all the way out). Then depress the release button and pull the knob and shaft out of the switch. Then unscrew the ferrel (sp?).
Disconnect the wires and remove the switch. Earlier trucks used screw-on connections, later are a big plug, I don't know what yours is.
#243263 11/12/2004 7:35 PM
I figured it out (thanks anyway). The problem was it was in pretty tight. The BIG problem is I flaked off a big piece of paint (grrrrr!!).
Now I will attempt to clean this nasty switch. [img]http://hesproductions.com/59sub/images/electrical/headlamp-switch.jpg[/img]
[img]http://hesproductions.com/59sub/images/electrical/headlamp-switch-2.jpg[/img]
More on Hotrodders
#243264 11/12/2004 10:57 PM
Cleaned it up and put it back together and she works great!
More on Hotrodders
#243265 11/12/2004 11:10 PM
'course, now you have to convince Kelly that everything is fine on the truck and something like that will NEVER happen again grin
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#243266 11/13/2004 8:33 AM
I love those switches. They can corrode, but are built so tough that a bit of cleaning and you're good for another 50 years. cool
1954 GMC De Luxe COE
#243267 11/13/2004 5:48 PM
Your right on the money.
More on Hotrodders
