| | | Forums66 Topics128,095 Posts1,056,078 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24308 08/25/2003 5:26 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Can anyone describe or direct me to a schematic of how the brake lines were run on a 49 1/2 ton? Mine were non existent when I purchased my truck. I know the line comes off the back of the master cyl. and crosses over under the tranny. Where does the line to the left front wheel come from. The service manual shows some type of T connected to the master cylinder. Mine did not have this on it. Is it supposed to? Any help appreciated. | | |
#24309 08/25/2003 6:14 PM | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | The brake line comes out of the MC, goes to the passenger side of the frame and tee's to the front and rear. The front line goes the right front wheel and continues behind the cross member to the left front wheel. The line the goes to the rear goes tee's to another line attached to the rear axle and that line goes to each rear wheel. Very simple, but if any line or connection fails.......Your screwed!  | | |
#24310 08/26/2003 3:02 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | dunfire, Thanks for the help. That answered my question about the left front line. The remnents of the line to the rear was in place and I had a pretty good pattern but the lines to the front were gone. | | |
