7 members (Donf, JoeDude, 48jim1ton, gswbbc, frogfarmer, Gdads51, Gib70),
109
Mod | | | Forums66 Topics128,035 Posts1,055,528 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Today the burb stranded me. The float is sticking on my 1 barrel. I rebuilt it 2 months ago. What's wrong? (235 6 cyl) | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sticking or sinking? if sticking you should be able to carefully bend it to clear everything, but it may be that there's something wrong with the needle or seat - if it's sinking you're best off to find a new one - I had one that started leaking this fall, and it flooded the poor 6 but good! Bill | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Opened the carb and there was a good bit of trash. Cleaned it out and cut the gasket a bit bigger around the floats just to be sure. | | |
