3 members (2-Ton, 78buckshot, texczech), 236 guests, and 11 robots.
Topics128,078
Posts1,056,035
Members48,433
#242943 11/04/2004 9:36 PM
MISSING THE 2 ROD BOLTS THAT GO ON THE LEFT HAND BARN DOOR. THEY GO IN FROM THE TOP & BOTTOM, ABOUT
18" TO 24" LONG. THE SCREW IN AT THE HANDLE ASSY
IN THE MIDDLE OF THE DOOR.
WHAT HAVE ANY OF YOU GUYS DONE TO REPLACE THE RODS TO MAKE THE DOOR WORK
FRAMEUP TRUCKS - 47/55.1ST
STILL PLAYING WITH TRUCKS
#242944 11/04/2004 11:51 PM
Go to your local hardware store. Pick up some threaded stock. Usually come in 4' lengths.
All different sizes.
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
#242945 11/25/2004 4:13 AM
while digging for some bits in the parts stash for my [future] panel, I ran across the set of NOS rods I picked up a while back, and remembered this thread -
as it sounds like you don't have the rods at all, FYI the dimensions are as follows:
short one is 19 1/8"
long one is 24 1/4"
both are 5/8" diameter and threaded 1 1/2" up 10-24
and the rounded slotted heads are 1/2" across with a rounded countersunk body - there's also a rubber antirattle bushing that fits the end closely
hope this helps! grin
#242946 12/01/2004 5:17 PM
RED 58,
THANKS FOR THE INFO.... cool
PICTURES ARE WORTH A 1000 WORDS
TRUCKMAN
#242947 12/02/2004 2:29 AM
Moderator
Moderator
Hey Bill, thanks for the info! I have mine apart right now for refurbing. No bushings on mine at all. I think I can do something with a bead of silicone, though.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
