0 members (),
145
Mod | | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 60 | MISSING THE 2 ROD BOLTS THAT GO ON THE LEFT HAND BARN DOOR. THEY GO IN FROM THE TOP & BOTTOM, ABOUT 18" TO 24" LONG. THE SCREW IN AT THE HANDLE ASSY IN THE MIDDLE OF THE DOOR.
WHAT HAVE ANY OF YOU GUYS DONE TO REPLACE THE RODS TO MAKE THE DOOR WORK
FRAMEUP TRUCKS - 47/55.1ST STILL PLAYING WITH TRUCKS | | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | Go to your local hardware store. Pick up some threaded stock. Usually come in 4' lengths. All different sizes. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | while digging for some bits in the parts stash for my [future] panel, I ran across the set of NOS rods I picked up a while back, and remembered this thread - as it sounds like you don't have the rods at all, FYI the dimensions are as follows: short one is 19 1/8" long one is 24 1/4" both are 5/8" diameter and threaded 1 1/2" up 10-24 and the rounded slotted heads are 1/2" across with a rounded countersunk body - there's also a rubber antirattle bushing that fits the end closely hope this helps! Bill | | | | | Joined: Sep 2000 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 60 | RED 58, THANKS FOR THE INFO.... PICTURES ARE WORTH A 1000 WORDS TRUCKMAN
FRAMEUP TRUCKS - 47/55.1ST STILL PLAYING WITH TRUCKS | | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | Hey Bill, thanks for the info! I have mine apart right now for refurbing. No bushings on mine at all. I think I can do something with a bead of silicone, though.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
