| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24272 05/29/2002 2:28 AM | Joined: May 2002 Posts: 2 Junior Member | | Junior Member Joined: May 2002 Posts: 2 | I've got 4" dropped coils to install in the rear of my '65 10 series, should I consider the pinion angle? Thanks for any input. hp
hp
#24273 05/30/2002 10:04 PM | Joined: May 2002 Posts: 20 Member | | Member Joined: May 2002 Posts: 20 | A 4 inch lowering job shouldn't cause a problem.If you experience any vibration or joint wear then you know its a problem.
Porky Pig is just a ham.
