| | | Forums66 Topics128,066 Posts1,055,874 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | a little tip about welding on your bolt, just because you own or have access to a welder, this does NOT mean that welding is a fix for EVERYTHING!
Right now I'm working on removing my lower A-arms on my '67, that some genius decided to WELD to the cradle. The u-brackets that rivet to the bottom of the cradle, that the A-arm shaft rests in are gone. In their place are scraps of metal, and makeshift brackets. :hammering:
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Jan 2007 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 48 | That's a bad scene! Were you driving the truck before finding this potential castastrophy? Bet you had some choice words for him when you found that level workmanship.
Joe -------------------------- '67 Chevy C20 fleetside, 250 inline, 3 on tree, heavy duty clutch and brakes, heater, steel bed floor ----------- "Tighten until the stud snaps, then back off half a turn."
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Buying an old truck that someone has already "fixed up" is like buying a box of Cracker Jacks... there's a surprise in every package Sometimes several | | |
