| | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | My 1951 3100 chevrolet truck has the deluxe fresh air heater in it. The heater control knob (maroon-warmer)twisted off the rod.I purchased a new after market knob and installed it with no luck.The knob doesn't grip the control rod. I took it back and they can't tell me the proper way of installing it.The tech guys don't have a clue,but they sell tons of them ? I explained that it wasn't any good just for looks,I want to use it.They exchanged it for another new one with no hassle at all. The control rod has little splines that should press into the knob.Do you fellow bolters know how to install the knob on the control rod ? What is the trick ??? A couple of pictures of the new knob. heater control knob back side of knob Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Maybe heat the rod and kinda "melt" it into the new knob? I know,,,you shouldnt have to do something like that to a brand new part,,but welcome to the world of repro,,"just like original" parts. Marty | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Tim,
I haven't seen these items, so this is a guess. Loctite and a bazillion others make two part epoxy compounds...everyone here knows J-B Weld.
Would it be possible to clean the shaft and little spines of all old knob material and make it bright and clean.
Mix your 5-minute two part epoxy and stick a little gob into the hole on the new knob and shove it on. When it dries, it should be just-almost-like new.
Because I haven't done this, maybe I am over simplifying it.
Stuart | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Stuart,i just posted some picture links in my original post. I will give it some thought while others chime in. Thanks ! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Tim, That's how I imagined it! If you roughed up the interior of the hole in the knob a bit, I'm pretty sure the epoxy routine would be bullet proof. I agree, wait and someone will have a BTDT answer. Stuart | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Stuart,what does BTDT stand for ? I don't understand the lingo . 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Been there, done that!
Maybe someone has done this very procedure and there is some obvious way to accomplish it that doesn't involve "Stu's method".
Stuart | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Isn't the idea to take the slpined metal hub out of the old knob and mount it in the new one? Also you should be able to get a knob from some old electronics equipment which has a set screw. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | truckernix,My broken knob doesn't have a metal hub or barrel in it.I've had this truck for 24 years,maybe someone changed it before me.Do you have a picture of an original knob showing this hub ? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | My repop kob was tight when I tried to put it on. I just "finessed" (real meaning is drove) it on. I think any kind of glue (like Gorilla) would suffice to hold it in place. Just make sure that its position is correct before you do glue it. If it broke afterwards, you could just use a dremel to clean up the shaft of any residue. | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | | | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | Clean the splines good,put the new knob in hot water for 5 min and push it on,let it cool,and it will stay on. Works for me Don | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | But, but... it says "Perfect Fit" in the catalog  | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Perfect Fit Manufacturing Company, Tiawan... :p | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I talked to mike at Jim Carters about installing the heater knob on the rod.He told me to heat the rod up and then push the knob on.I heated it with a propane torch.I then pushed the knob on and it melted around the knob and splines.I then had to hold it still for a moment so it didn't shift crooked.I then stood it up and let the vise hold it over night.I just installed it and it works great so far.I did mark the rod for placement of the knob before hand.I didn't want it in the wrong position.
It's always nice to purchase parts from people who actually work on these old trucks. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
