7 members (Greg_H, Joe H, Tinker5, Ridgeback, WICruiser, 2-Ton, Bill Hanlon),
132
Mod | | | Forums66 Topics128,195 Posts1,057,376 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | Does anyone know what the biggest wheel and tires that will fit under a stock fendered 1951 chevy 3100. Standard width rear end? thanks
Tony Jacques
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | My 1 ton has the same fenders as your truck, and the tallest tire I would try is an 8R19.5, about 32 or 33" tall
I ran a set on my truck for a while and liked them.
You may not be able to fit them on a 1/2 ton, depending on where the wheel is placed in the opening up and down, not sure if it is the same as the 1 ton. Also you won't find any 19.5 wheels to bolt to your hubs.
Grigg | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A 31x10.50x15 is about the biggest that will fit without rubbing, you might be able to get away with a taller narrow tire like Grigg says, if you keep the section width no more that 8-9".
Bill Burmeister | | |
