| | | Forums66 Topics128,092 Posts1,056,457 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | As some of you know, I had a bit of an accidente with my '55 a while back. Well, after being thoughorly depressed about it, and putting off working on it, I finally got things going back together. Just fired it up and took a trip aound the block. First time it's moved under it's own power for almost 10 months. let me tell you, it felt GOOD! Now just a bit of welding on the end of the frame, put the grille back in, and whenever I get it, install the new bumper and fix the guard, and it'll be on the road again!
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | Bill, That is great news, and sounds like You will be appreciating it even more now... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yeah, just gotta stay away from them Volkwagens! :punch:
