| | | Forums66 Topics128,055 Posts1,055,785 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 12 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 12 | On my 71 4x4 with power steering ,there seems to be alot play in the steering sector. I know that in the past I have adjusted for this with that set screw on top of the sector. I also know you can really mess it up by playing around with it . Does anyone have information on how to go about this, I just cant remember the procedure.
Keep em on all fours! my 72 | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If the sector shaft goes back & forth without turning when you move the worm shaft It will need rebuilding. If there is looseness in the input shaft you can loosen the lock ring & tighten down the adjustment nut just enough to remove the looseness. You can tighten down the adjust screw on top but very little. Go about 1/4 turn & try it out. If it binds or doesn,t feel right back it off. If the play is excessive you will need a reman. box. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
