2 members (Hotrod Lincoln, 2-Ton), 149 guests, and 2 robots.
Topics128,087
Posts1,055,999
Members48,430
#240033 08/31/2007 5:26 AM
I'm replacing the kingpins, bushings, and thrust bearings on my '49 Chevy 1/2-ton truck with all new parts. My shop manual says nothing about lubricating the thurst bearings. Should I pack grease into the thrust bearings before assembling the steering knuckle? Thrust bearings are new and not currently lubricated. - Thanks.
#240034 08/31/2007 5:43 AM
norcal49er,
It never hurts to hand pack something like this with grease. I think that after you install all the new parts and grease the pins for the first time, some of the grease pumped into the bottom Zerk will be forced up and into the thrust washer.
Stuart
#240035 08/31/2007 6:09 AM
Yep, they get greased with the king pins, but I would pack them really good to start with too.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#240036 08/31/2007 2:52 PM
Done. Thanks. Spindles are back on the frame.
#240037 08/31/2007 3:16 PM
I recently converted my stock king pins and bushings to the Royal King Pin set from Stainless Steel Brakes. More precise and smoother steering. Highly recommended for front end improvement.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
#240038 08/31/2007 7:58 PM
http://www.stainlesssteelbrakes.com...0Kits&model=Straight+Axles&year=
Is the link for the new king pin set.
It took me a while to find it on their site, so I emailed SSBC to let them know, and also they have next to no info on them.
Do they only fit 1/2 ton, or do they offer sets for larger trucks, they don't say either way.
Also they don't mention if the needle bearings in place of bushings help or hurt the load carrying ability of the truck? And how long they last compared to bushings?
I have asked all these questions, and will post their reply, if they do.
Grigg
---All pictures---
#240039 08/31/2007 8:17 PM
I think that kit is just for 1/2 ton. I recall seeing that in one of thoir print ads, perhaps in R&C.
Bill Burmeister
