| | | Forums66 Topics128,185 Posts1,057,279 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 1 Junior Member | | Junior Member Joined: Aug 2007 Posts: 1 | Always been interested in the early GM trucks but my first project (67 SS Chevelle) isn't done yet and hadn't planned on a 2nd project. However, I ran across a '52 Chevy pickup down the road from me. I was told that it is a project but "solid", has the original engine which runs good, has a 9 foot box (is this rare?), and is willing to take $900 cash.
I have not looked at it up close yet, just driving by. Besides the typical rust areas, what should I look for? Depending on its shape, is this a good price?
Thanks for any info. | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | The 9' box says to me that it's a 1-ton, model 3800. Not common at all, but not rare just yet. Don't buy it if you want a hot rod, because they're heavier by far than a 1/2 ton, and not as desirable. However. If you're thinking of a restoration or a truck for heavy work, well.. I sure like mine. Be advised that you might fing the original 5.14 diff ratio. With mine, I had a best cruising speed of 35 - 40mph, and a flat-out maximum of maybe 50 mph with the old 7.00x17" wheels. I've since swapped to 235/85x16" radials (same profile) and a 4.10 ratio, and I am happy. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | It runs that is good very good but the motor is the easiest and can be one of the smallest expenses. Check the frame is it straight. Is it rusty. If the frame is bent and rusted then you have alot of work that would destroy any budget. Same with the body. Rust will be found but is it surface rust. Tap it if your fingers goes through it then replacement is neccesary. Again expense and time that will destroy budgets. These are the areas to look at. In my opinion at least. It sounds though like it would be a good project. Also is it a farm truck or a city truck. Farm trucks will be beat up more body wise but most farmers will have there pickups purring like a kitten. | | | | | Joined: Nov 2004 Posts: 2,423 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,423 | Jump on it! If it runs and drives, then it can be justified, as it can be useful as it is. Then it can be your next project when your ready. If two projects turn out to be too many, you can always sell that '67 to me. You can't get much for $900 anymore, make sure the title is good and matches the tag on the truck. If it is not too far gone (rust wise) and is still mostly intact, it doesn't sound like a bad deal. Just remember that it is a heavy duty truck, and if you rather have a 1/2 ton, you would be better off to pass and wait for one. Welcome to the "Bolt" John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jun 2007 Posts: 2 Junior Member | | Junior Member Joined: Jun 2007 Posts: 2 | "Solid" means no cab corners, no cab floor, non-existent rockers, Bullet riddled glass and a bed that is 25% solid. BUY IT, ITS PERFECT!!! | | |
