1 members (Otto Skorzeny),
115
0
Mod | | | Forums66 Topics128,049 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | Yesterday I was at my workbench and happened to look at the fire extinguisher. The nozzel on the end was plugged tight with dirt from a mud daubber bee. I took off the nozzle and cleaned out about 1/2" of hard mud and bee larvae. Maybe this only happens in my neck of the woods, but it's worth a quick look. Jeff
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Probably a good idea just to be safe, however most fire extinguishers I've used would blow the nest and the wasp out of it.
~Jim
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That's a hot tip. It reminded me I haven't checked mine in a while. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I use an Inspection Card like they use at work(when I worked/retired  to keep track of when I last safety checked it.
Drew
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a guy comes around here once a year and does a check on my whole building, for free .... called the fire marshall  :mad: :blat: :hammering: Bill | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Dirt Daubers will fill the air inlet ports on my air tools in a matter of days. I've found that sticking a golf tee inside puts a "no vacancy" notice that they can't ignore!!! Spiders (the widow kind) will take up residency in the center of spools of wire as well as in a pair of boots and if you're sawing up 1X12's you'd better watch your fingers when seperating boards as the mini-scorpions find them inviting.
Just a few of the benefits of living in the Sunshine (and bug) state.
Dave | | | | | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | Ah North Dakota were there is no scorpions or blackwidows. Only a cloud of mosquitos in the summer and bitter cold in the winter. I work in an shed no heat no cooling and basically open to nature. But I have never had problems like that with insects. I suggest a can of Raid. As for the fire extingusher. Its a handy thing to have. I have two and although I haven't checked them in awhile its a nice to see them hanging on the wall. Specially when grinding away bolts well playing with 30 old gas ,carb cleaner, brake cleaner, sea foam, and few other explosive material. Safe maybe not but an adreline rush yes.  One last thing may I suggest a hose of sorts accesible just in case something big goes down. A fire extingusher won't ruin things but likewise sometimes you just need a little more. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That's really a good tip & one you wouldn't want to discover you have a problem with when trying to put out a fire. Thanks.
| | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | As for spiders and dirt dobbers, I use about 12 Raider Foggers (the kind that put out the smoke) every 3 months. It rids the shop of spiders, crickets, flies, and wasps. The smoke doesn't settle on anything like the spray foggers do. But they really get rid of the bugs.
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I had that problem with the extinguishers in my garage. After cleaning them out, I took a small piece of painters tape and stuck it to the end of the nozzle. Keeps the insects out and is easily blown off if you need to use it. Another area to check is the bottom of the extinguisher, wasps sometimes tend to build nests there and you don't see them until you use the extinguisher. Every month I pick mine up and turn them upside down. Turning it upside down helps to keep the powder inside from packing and you'll also spot a wasp nest if it's there.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | same thing happened to my grandfather. he started to put out a fire in the back of a truck in front of his shop only to find a dirt daubers nest in the nose. it was a smaller one but the tank didn't blow it out, he was stuck trying to put it out by hand. hr | | |
