| | | Forums66 Topics128,012 Posts1,055,313 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | I am having brain cramp and would like some help. I am finally putting my grill back on after front end work and painting and can't seem to find or remember what fasteners are used to attach grill to inner and outer fenders. Are they a hex head lag screw or bolt?? and which way are they started....from inside of grill or from the inner fender  ...thanks for help. :p Chuck
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I did mine recently, and used hex head bolts, going from inside the inner fender to the nuts attached to the grille frame. | | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Hey Tom, Thanks for the info....I am working solo on this and was having a tough time "lining up" all the holes, and for some reason wasn't able to get the new stainless hex bolts started.
Blue 50
