7 members (55shaker, Hotrod Lincoln, mason86, Paul Mullen, Peggy M, walter74, Bill Hanlon),
63
0
Mod | | | Forums66 Topics128,050 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | I have a Ranco H11 heater control valve out of a 47 chev that I need to test? I pulled the entire heater from this truck, the heater core was great just needed to had boiled and cleaned, blower motors work great, so I figure before I pony up $$$ for a new valve I would test this one to see if it still good, any ideas? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | some rubber/plastic tubing, hose clamps, a cork will set you up - hook one end up to a garden hose, plug the other, see if it blows up or stands the pressure Bill | | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | My water preasure runs 80 psi, therostate on the truck 7 psi could that cause a leak that was not there before? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well, ya don't hafta turn the tap on full bore! it should take say, 15 lbs if it's gonna be good, if it starts leakin at 15-20 lbs it wouldn't have lasted long - there's mainly just a rubber grommet that can be bad, repair kit from NAPA: Napa/Balkamp #BK660-1000 .... and get a regulator on yer house line, a lot of household stuff gives out too soon if pressure is above about 60# alla time Bill | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | tap pressure is the same whether you crank it full bore or just a little bit. How about using an air compressor set at 7#, valve should seal tight, then open up and let air (water) flow through. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Wouldn't the proper test be whether the thermostatic feature functions properly...wouldn't it need some hot water going through it. It might not leak, but this might not mean 'it works'. :confused:
Stuart | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | tap pressure is NOT the same if you don't open the tap alla way, a flow restrictor is a pressure restrictor, put a pressure gauge on it if you don't believe that ... or just try it on your lawn sprinkler as Stuart sez, if it has the thermostatic capillary tube on it, you might want to check that, but it's the capillary tube that needs to be heated Stoo, and if it's not broken and the guts of the valve aren't corroded, it'll work .... the leaking part is the main problem those things develop, thermostatic or manual, and water is the test, not air - I've rebuilt 2 of them cuz of leaks with the kit I cited above Bill | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Well Red, not to nit-pick too much here but "that's my story and I'm sticking to it". I was assuming the valve would be tested in the closed position. If you connect a faucet to it, crack the tap open, and wait a little while, the pressure in the valve will be the same as the water pressure to your house. And, on a '47 I thought the "thermostatic feature" was pull the knob out if you want it warmer and push it in if you want it cooler. | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Hey red58, I agree that a flow restrictor will reduce pressure on the outlet of the device with flow, but you said plug one end. The pressure will continue to build till it equalizes with whatever the supply pressure is. It doesn't matter how little or much you turn on the valve. That will just determine how fast the flow equalizes. Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no flow is no flow, low flow is low flow ...whatever ... try the test, it'll work, my city pressure is about 90#, the regulator I put on the building cuts it to 70 measured at the furthest hose tap, my hose turned low, hasn't blown out anything I've tested with it, rancos, cores, or radiators .... maybe someone else has a better suggestion that won't involve hydraulic theory Waldo, I said either it has a capillary thermostatic control or is manual - pretty easy to see if the valve has the capillary tube or not, which allows it to automatically maintain the temp setting you select - ie: restrict the flow for less heat, or not for more ... this guy could check it for ya , spiff it up, and put in the $5 washer too, shouldn't run more than $100 Bill | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | When I checked mine, I went "air over hydraulic." I made a setup similar to Bill/Red58's description. I used a bicycle inner tube filled with water connected to one of the sides of the valve. Then I used a bicycle pump to apply pressure. I could regulate the pressure pretty easily this way.
Mine leaked, so I bought a really crummy reproduction (do a search for "TxLaTx crabbing about heater control valves" and it'll probably light up) and re-jiggered it to work. I kept the old one and will play around with changing out the NAPA BK660-1000 grommet that Red58 mentioned later this year.
While I'm on the soapbox, here's another thing I came across: I put my old valve in some 5% vinegar and that baby came out looking VERY good! It dissolved all of that gunk that had been accumulating for 50 years. Just don't leave it stewing for too long or it could end up damaging the metal joints. After pickling it and giving it a good rinse, I lubed the mechanism with moly grease and it seems to work very well. Prior to the dip, it would barely work even after applying a lot of force to it.
Bill | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Originally posted by red58: , my city pressure is about 90#, the regulator I put on the building cuts it to 70 measured at the furthest hose tap,
Bill Man, you guys got some pressure up there, no way my 40 y/o pipes would hold that. Ours runs about 40 after the reg, only about 50 psi w/o(straight off the line). | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Pascal's hydraulic theory says that pressure in a closed hydraulic system is the same no matter where it is measured. If the hose bib in front of the house has 70 lbs of pressure, the hose bib in the far corner of the house would have 70 lbs of pressure too. When you turned them on, they might have different flows, but the closed pressure would be the same. Stuart | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | actually Tx Bill, if you hook it all up and then turn on the water [1/4 turn], you've got "air over hydraulic" and I'd be sure that folks using original valves from years when the cooling system was zero pressure, on systems that have been modified to 15# don't have valves blowing up  works for me 64fleetside - there was a lot of grief in town when they "upgraded" the water system - some folks didn't pay any attention to the warning that regulators should be installed, blew out old water heaters among other things, but my place was plumbed by me with a 1" feedline for commercial, no problems here with 70#, and great for the apple processing biz and Stoo, the hose tap in front of my house is before the regulator Bill | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Stoo gives up too...you win! :rolleyes:
Stuart | | |
