4 members (2-Ton, 78buckshot, TUTS 59, Wally / Montana), 80 guests, and 2 robots.
Topics128,060
Posts1,055,835
#237477 07/19/2007 4:46 AM
Guys any advice on hood hinge springs? I am sure most of the vendors are sourcing from China now, but I would think there has to be a US manufacturer of them? Thanks!
#237478 07/21/2007 2:27 AM
I bought some and they were weaker than the ones I took out. I put my old ones in and can give you a good deal on a new pair only used a little. They were made by CounterPart. If you find some made in the USA let me know.
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
#237479 07/21/2007 3:19 AM
Not sure about the US manufacturer thing. I got mine from LMC truck for my '70 C10 and they were plenty strong. New springs and new hinges and now the hood closes down great but I have to put some weight into it to pull it down.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
#237480 07/21/2007 5:21 PM
Junior Member
Junior Member
I've used hood hinges on my '57 from both LMC and Brothers, identical and IMO excellent quality. If made in USA or originality is important, there are some places that rebuild original hinges (door and hood).
#237481 07/21/2007 5:34 PM
Thanks for the advice on LMC and Brothers. I was thinking US might be important to avoid the issue Eric mentioned.
#237482 07/21/2007 10:35 PM
the primary problem with hoods that don't work right is the hinge pins being worn, requiring new hinges [and the TF repros are good] - rarely do the springs get weak enough to need replacing alone
Bil
#237483 08/12/2007 5:05 AM
Red,
Help me understand how the hinge pin being worn would cause the hood to not stay in the full up position. Also, how do I check to see if that is what it is? Thanks!
#237484 08/12/2007 5:22 AM
having the hinge off is the easiest way to see it - if the main pivot pin is worn sloppy [the hole mostly], the hinge halves move so the spring is pulling the halves in directions that result in releasing spring tension - might be able to see it if you just take the springs off .... if you have a hood that doesn't lay flat at the back when closed, and it does when you take off the springs, worn hinges are the problem - usually the problem when the hood won't stay all the way up as well
new hinges I've gotten come with new springs, and they worked great, but I've used old springs on new hinges, and that worked fine too ... takes a lot to wear out those springs!
