1 members (walterhvogel), 87 guests, and 3 robots.
Topics128,035
Posts1,055,559
#237447 07/18/2007 6:37 PM
hi all been offered a 85 rear wheel drive pontiac bonneville brougham
anybody know if this is a good candidate for a frame swap with my 49 ad truck is itv a separate chassis (frame)?is it same as 80s monte carlo as i think a few have used that frame
also what engine should this have the guy says 400 but i dont thinkl hes too clued up iv read 305 wouldthat make it a chevy unit??
need info asap or its sold!
#237448 07/18/2007 7:34 PM
IF its the same as the '78 to '88 Monte its a g-body frame.
The wheelbase is 108 inches, which is 8 inches SHORTER than a '49 1/2-ton.
Its a perimeter type frame instead of the ladder type originally under the truck. This means the rails bend outward between the axles, and at the cowl the frame is WIDER than floor of the truck.
The front track width is about perfect for an AD truck.
The rear track is a little narrow for an AD truck. In fact using wheels with no offset the bed would need to be tubbed to make room for the tires.
These frames will take most any GM motor, so it could have a Pontiac 400 in it, or even a Cadillac 500, which I've been told is a popular swap, but a US made version came with a 305 or maybe a V-6.
I would say its a BAD candidate unless you are prepared to do a lot of work...
And I'm in the process of using that frame on one of mine, so while I'm telling you its not a good idea, I'm also doing it myself. I'm three years into the project and might be another couple from driving it.
#237449 07/18/2007 7:50 PM
The Bonneville isn't the same as the G body (Monte Carlo). It's actually the same as the GM largebody cars, like the Olds rear drive 98/88 and the Roadmaster/225/LeSabre/Park Avenue. It will be wider, and it's a perimeter style frame, which will interfere with the running boards. Most likely the engine will be either a 307 or 350 Olds, might also have a Chevy smallblock, but no larger than a 350. I agree with OldSub, an S10 frame would be a much better candidate.
Bill Burmeister
