12 members (panel fan, FAST55, frogfarmer, JW51, Wayne67vert, Gdads51, Lightholder's Dad, gswbbc, 48jim1ton, tclederman, Ponchogl, 1 invisible),
71
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 45 New Guy | | New Guy Joined: Dec 2005 Posts: 45 | Doing an S-10 frame swap and need to know if there is supposed to be a gap between the bottom of the cab and the running board or does the running board fit tight against the cab. If there is supposed to be a gap, how big is it.
Thanks, | | | | | | Anonymous Unregistered | | Anonymous Unregistered | You can position the running boards using the front and rear fenders. The bottom of the running board should be flush with the bottom of the front fender and the rear of the running board is bolted to the rear fender. That will set your gap under the cab which is 1.25" on my 54. | | |
