10 members (Donf, Gdads51, Woogeroo, Jon G, DennisM, JoeDude, rfs56trk, Jaison, frogfarmer, Hotrod Lincoln), 164 guests, and 3 robots.
Topics128,035
Posts1,055,528
Members48,425
#236876 07/08/2007 2:43 PM
Doing an S-10 frame swap and need to know if there is supposed to be a gap between the bottom of the cab and the running board or does the running board fit tight against the cab. If there is supposed to be a gap, how big is it.
#236877 07/08/2007 3:30 PM
Anonymous
Unregistered
Anonymous
Unregistered
You can position the running boards using the front and rear fenders. The bottom of the running board should be flush with the bottom of the front fender and the rear of the running board is bolted to the rear fender. That will set your gap under the cab which is 1.25" on my 54.
