2 members (Hush, delky),
141
0
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | I have replaced all the felt and rubber that I know of, but when I close my doors and the windows are down, they rattle against the metal channe edge of the felt - am I doing something wrong???
1950 AD Chevy 235 - 3 on the tree - straight pipe & cherry bomb - baaaam bam bam bam bam I am no mechanic, but I am going to try on this one!
| | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | The metal channel that is covered with felt should remain in a channel that continues on down into the door, otherwise it could rattle against the window. When the window is up, there is nothing for the metal to rattle against.
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you replace the metal channels that have the felt inside, the windows will be quite stiff to roll up and down. There would be no chance of a rattle then. | | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | The metal channel is new too, it is just when the window is all the way down. It is not in the channel snug then - well, not on mine. That is why I am thinking that I must be doing something wrong or it is the nature of the beast.
