8 members (tclederman, Hotrod Lincoln, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom, Otto Skorzeny),
179
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23575 12/20/2003 11:09 PM | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | I have a 1950 1 1/2 ton GMC 350 truck with a 3 speed M43 Brownie but can't find anything about this box on the net. I suspect that it doesn't belong on this truck but I'll keep it if gives me a better cruise speed. Does anyone have any info on these? | | |
#23576 12/21/2003 1:51 PM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Stricly a guess here. Wasn't a brownie used in Macks? This isn't a quad box is it? Try one of the Big Truck forums, and you should find it quickly. | | |
#23577 12/21/2003 6:06 PM | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | From what I have been able to find, some were used on the big GMCs but I can't seem to find this model. Another thing that makes it tough is the tag lists several different companies and their divisions. If I remember correctly it goes: Brown transmission co a division of ????? a division of ?????? a division of Spicer Transmission. Of course Spicer's site doesn't mention it at all. | | |
#23578 12/21/2003 6:23 PM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | http://www.6066gmctrucks.org/spicer-5831-b.htm http://www.thedieselstop.com/archiv...ollapsed&sb=5&o=&fpart=1.htm Your looking at a Brown-Lipe transmission. I don't have anything on an "M-43". My guess is that stands for Manual trans 4 speed main, 3 speed aux. Brown-Lipe was a supplier to GMC through '42 at least. That's where my info ends. I do have a number of models listed. If you find a 3 digit or 4 digit number (numbers-no letters) post it and I might have some info for you. | | |
#23579 12/21/2003 8:09 PM | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | The only thing I have found so far is a serial number: 014821
Thanks | | |
#23580 12/21/2003 9:17 PM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | How many speeds is it? Does it have reverse? Can you post a Side-On pic? | | |
#23581 12/21/2003 9:34 PM | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | rd, If your truck is a 350 series, you've got a 2 Ton, 16000lb.gvw truck. GMC's 1 1/2 Ton truck during that era was a 300 series, 14000lb.gvw. As far as the aux. trans. is concerned, a good way to tell if it is factory, or added on later, is to look at the workmanship of the way it's installed. | | |
#23582 12/21/2003 9:58 PM | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | It's a three speed with no reverse and the installation is a farmer special. The pictures of the Brownie are at www.salemfarmgarden.com/truck pix Thanks | | |
#23583 12/21/2003 11:09 PM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Well, let's see. I've got models 6031, 6031A with direct on 2nd and OD on 3rd. Same with a 5531 model. And a model 703 used in conjunction with 3 and 4 speed units. I can't get the link to work. | | |
#23584 12/21/2003 11:28 PM | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | For some reason it left off the pix part www.salemfarmgarden.com/truckpix Thanks | | |
#23585 12/22/2003 12:59 AM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Nothing in my book is apparent that yours is listed. It looks definitely related. It's probably after '42. See if you can find a Motor book from the 50's. What do you want to do with it? | | |
#23586 12/22/2003 1:03 AM | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | Thanks for looking. I am hoping to rebuild and use it. Any ideas on cleaning it? What the pictures show are after a good can of oven cleaner and a 3000 psi pressure washer using hot water. That stuff is really stuck! | | |
#23587 12/22/2003 1:23 AM | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | rd, What's the "Truck", look like | | |
#23588 12/22/2003 2:30 AM | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | Duals on the rear, 12' dump bed, 270 straight six and a good straight cab that is in a million pieces in my shop right now. I'll post some pictures tomorrow. | | |
#23589 12/22/2003 7:07 PM | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | I posted some pictures of it this morning. | | |
#23590 12/22/2003 8:15 PM | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Good look'in 'ol truck ya have there rd. Thanks for the pictures. | | |
#23591 12/23/2003 3:22 AM | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | Thanks Spanky! If I can remember the camera tomorrow I'll take some current pictures. The cab goes out for bead blasting tomorrow. | | | | | Joined: Sep 2017 Posts: 23 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 23 | If anyone is still looking at this. The brownie was a Watson M43 3 speed brownie. Over, under, and direct. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Dummie here. What's a brownie? Maybe a multi-speed rear end?
Why is it called a brownie? 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | "Brownie" is the nick name for an auxiliary transmission made by the Brown-Lipe Company. Mike B  | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Watson boxes were labeled such, bought or taken over by Brown-Lipe, Spicer. Not as strong as later boxes labeled 5031, 6041, etc., the 5, 6 stands for Engine torque rating in hundreds, Fine for a gasser, not diesels.
The left shift rail, rear position should be OD. Move the shift rails and count the revolutions. With the shift lever installed, OD would be right and fwd.
Ed
