| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 44 | Guys,I tried the parts wanted with no luck ,can anyone suggest where to get used wing vent glass frames for my 53 thanks [email protected]
Popa Kents Body Shop
| | | | | Joined: Apr 2007 Posts: 29 Apprentice | | Apprentice Joined: Apr 2007 Posts: 29 | If it is flat glass could an automotive glass shop cut some for you. I realize you said used, but you would be amazed at how inexpensive flat glass is. Just a thought | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I believe he wants frames. There were several posts a month or two back and I have seen vent frames for sale. I believe they run pretty expensive.
~Jim
| | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | Try Robert Atkins at Split Window Restorations in Portland Oregon. 503-777-3724 He ships all over the country. | | | | | Joined: Jul 2006 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 44 | thanks I believe I have some located
