2 members (HandyAndy, mick53),
78
Mod | | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23520 01/04/2004 12:34 PM | Joined: Jan 2004 Posts: 1 Junior Member | | Junior Member Joined: Jan 2004 Posts: 1 | I have a 1967 stepside straight-6 and want to replace it with a '73 455 buick. Will it fit, who makes the mounts or will the stock buick mounts work. Has anyone seen this application before? Thanks
Thanks, Bryan
#23521 01/04/2004 5:37 PM | Joined: Oct 2003 Posts: 23 Junior Member | | Junior Member Joined: Oct 2003 Posts: 23 | You can swap just about any engine into these trucks...Adapting the new engines mounts to a mount (riser) is the trick...The riser will be the piece that goes between the engine and the frame...You will notice there are different holes in the crossmember to accept different risers...In fact if you were to install a small block Chevy into your truck.you would use the inline six risers and move them to the other set of mount holes...I'm in the middle of installing a 455 Olds in a 72 C10..I picked up the entire riser set up from a mid/late 70's Chev truck that came with the 350 Diesel..The rear mount shouldn't be too tough...I'm going to use a short TH350 with dual bolt pattern.(fits small block and big block)..but a long TH350 should work because the frame rails are pretty straight and a rear crossmember can be bolted in...
If all the cylinders ain't in a line it ain't cuttin it..
#23522 01/04/2004 9:27 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | My brother once had a '62 Chevy pickup with a Buick 455. He bought it that way, and never removed the motor so I don't know what the mounts looked like. But the motor fit fine, and it was a nice fast little truck.
He sold it without telling me it was for sale. I wanted to shoot him, because I wanted that truck!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#23523 01/13/2004 4:03 PM | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | A few years back, I bought a Delta 88-1974 for a couple hundred. Sold 4bbl 455 & trans for $800 & car for $150. Fellow who bought the motor/trans put it in a Chevy truck, but don't remember what year.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
