Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Woodcmiami, Peggy M, Southerntruck), 117 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#23520 01/04/2004 12:34 PM
Junior Member
Junior Member
1 Offline
I have a 1967 stepside straight-6 and want to replace it with a '73 455 buick. Will it fit, who makes the mounts or will the stock buick mounts work. Has anyone seen this application before? Thanks
Thanks, Bryan
#23521 01/04/2004 5:37 PM
I
Junior Member
Junior Member
I Offline
You can swap just about any engine into these trucks...Adapting the new engines mounts to a mount (riser) is the trick...The riser will be the piece that goes between the engine and the frame...You will notice there are different holes in the crossmember to accept different risers...In fact if you were to install a small block Chevy into your truck.you would use the inline six risers and move them to the other set of mount holes...I'm in the middle of installing a 455 Olds in a 72 C10..I picked up the entire riser set up from a mid/late 70's Chev truck that came with the 350 Diesel..The rear mount shouldn't be too tough...I'm going to use a short TH350 with dual bolt pattern.(fits small block and big block)..but a long TH350 should work because the frame rails are pretty straight and a rear crossmember can be bolted in... wink
If all the cylinders ain't in a line it ain't cuttin it..
#23522 01/04/2004 9:27 PM
My brother once had a '62 Chevy pickup with a Buick 455. He bought it that way, and never removed the motor so I don't know what the mounts looked like. But the motor fit fine, and it was a nice fast little truck.
He sold it without telling me it was for sale. I wanted to shoot him, because I wanted that truck!
#23523 01/13/2004 4:03 PM
A few years back, I bought a Delta 88-1974 for a couple hundred. Sold 4bbl 455 & trans for $800 & car for $150. Fellow who bought the motor/trans put it in a Chevy truck, but don't remember what year.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
