0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#235050 06/02/2007 6:41 AM
has anyone had problems with door weatherstriping around doors on 48-53 trucks , I have put new Counterpart rubbers around but does not close properly anymore
#235051 06/02/2007 11:59 AM
Where did you buy the rubber - which supplier?
Mine's a '54 ... but it's the same deal:
Read This
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#235052 06/02/2007 1:44 PM
I found that when I did the door seals on my 54 and several other project trucks, that after I installed the new seals, I had to adjust my latches down in several intervals.
It wasn't that the door seals were "defective"....I was just expecting a little too much, a little too soon. Giving them a little extra "cushion" for a week allowed the seals to conform to the body curvatures and then I could get my final adjustment and fit without any wind noise and my latches caught every time.
Backing off on the striker plate slightly and giving the seals a week, should do the trick. Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#235053 06/03/2007 5:02 AM
Alan we got from Truck shop, your rubber looks like ours I will try again. Roger
#235054 06/03/2007 12:34 PM
You probably need to adjust your door latches and strikers now.
I dunno if '53s are like 54s ... but here's my bit about adjusting strikers and latches:
See Here
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
