| | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 39 Member | | Member Joined: Dec 2002 Posts: 39 | has anyone had problems with door weatherstriping around doors on 48-53 trucks , I have put new Counterpart rubbers around but does not close properly anymore | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Where did you buy the rubber - which supplier? Mine's a '54 ... but it's the same deal: Read This
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I found that when I did the door seals on my 54 and several other project trucks, that after I installed the new seals, I had to adjust my latches down in several intervals.
It wasn't that the door seals were "defective"....I was just expecting a little too much, a little too soon. Giving them a little extra "cushion" for a week allowed the seals to conform to the body curvatures and then I could get my final adjustment and fit without any wind noise and my latches caught every time.
Backing off on the striker plate slightly and giving the seals a week, should do the trick. Hope this helps.
Dave | | | | | Joined: Dec 2002 Posts: 39 Member | | Member Joined: Dec 2002 Posts: 39 | Alan we got from Truck shop, your rubber looks like ours I will try again. Roger | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | You probably need to adjust your door latches and strikers now. I dunno if '53s are like 54s ... but here's my bit about adjusting strikers and latches: See Here
