1 members (Forty9), 96 guests, and 1 robot.
Topics128,072
Posts1,055,903
Members48,429
#234828 05/27/2007 8:14 PM
Junior Member
Junior Member
can anyone help me,i've got a 1964 swb chevy and it's 6 lug will any other 6 lug wheels fit it,i've got some 10" slots off a 72 4x4 and there 6 lug i'd like to know before i dismounted one
#234829 05/27/2007 8:26 PM
Pretty much any GM 6 lug wheel '70 and earlier on 2wd and '87 ('91 for 'burb and Blazer) for 4x4 rims will work. Avoid the '88 and later 6 lug rims, the offset is different and will rub. You could also use some jap truck rims, but again, there's some offset issues, especially on the solid axle trucks.
Bill Burmeister
#234830 05/27/2007 11:14 PM
The best method to check fit, is to mount one on the truck, with or without a tire. I have a set of American Racing six lug rims on my 2000 Chevy Tahoe that will bolt on any of my '64-'66 Chevy 1/2 ton trucks with the factory six lug hubs. Off set is not usually an issue if you are running factory drums.
The wheels of the '72 4x4 should fit with no clearance issues. Good luck with your search.
Tony
