7 members (Wayne67vert, baldeagle, 74cheyennesuper, NorCal52Suburban, Ponchogl, Peggy M, NJC),
60
Mod | | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23482 11/29/2003 10:37 AM | Joined: Feb 2003 Posts: 45 Member | | Member Joined: Feb 2003 Posts: 45 | Anybody out there think I should take my bed off to install all new brake lines??? :confused:
1950 1/2 ton 3 window
#23483 11/29/2003 3:00 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | If you need to take the bed off for another reason, it would make the job a little easier.. Don't take the bed off just to replace brakes lines..
You need to get under the front of the truck as well. You aren't going to pull the cab off are you ??
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#23484 11/29/2003 8:41 PM | Joined: Mar 2003 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 313 | If you are going to remove your bed wood for any reason, that would be a help. Got my wood out for replacement, so I am taking care of anything under that now so it is easier. | | |
