1 members (edgardo),
79
Mod | | | Forums66 Topics128,057 Posts1,055,808 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 3 Junior Member | | Junior Member Joined: May 2007 Posts: 3 | can anyone help me,i've got a 1964 swb chevy and it's 6 lug will any other 6 lug wheels fit it,i've got some 10" slots off a 72 4x4 and there 6 lug i'd like to know before i dismounted one | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Pretty much any GM 6 lug wheel '70 and earlier on 2wd and '87 ('91 for 'burb and Blazer) for 4x4 rims will work. Avoid the '88 and later 6 lug rims, the offset is different and will rub. You could also use some jap truck rims, but again, there's some offset issues, especially on the solid axle trucks.
Bill Burmeister | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The best method to check fit, is to mount one on the truck, with or without a tire. I have a set of American Racing six lug rims on my 2000 Chevy Tahoe that will bolt on any of my '64-'66 Chevy 1/2 ton trucks with the factory six lug hubs. Off set is not usually an issue if you are running factory drums.
The wheels of the '72 4x4 should fit with no clearance issues. Good luck with your search.
Tony | | |
