| | | Forums66 Topics128,049 Posts1,055,638 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Justin, I think that you will find the hole on the backside has a small area near the outside that is cut out slightly larger than the bore. This will have a very shallow depth but forms a ridge. The result is that the swaged material fills this in and makes it extremely difficult to drive it through. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The second link above tells the story that I was trying to explain. | | | | | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | I have already removed both ball studs on my old steering arm and it doesn't fit with the 53 drag link and pitman arm. The drag link end is too long and hits the axle when steering. The guy that sold me the 53 drag link and pitman arm has found the left side steering arm from the same assembly and is going to send that out. It has the hole on the drag link side and the ball on the pitman arm side, which I will punch out when I get it. | | |
