4 members (Peggy M, Gray_Ghost, Wally / Montana, 2-Ton), 106 guests, and 2 robots.
Topics128,052
Posts1,055,717
Does anyone know if they make patch panels for the rounded areas on the firewall of my 55 cameo? I think ductwork is the purpose of these areas. Mine look to be full of putty.....
no patches made for that area - called the air plenum, the bulbous box on the side of the cowl, under the back of the fender - channels the air from the inlet on top the cowl to the air vents on the kick panels inside - always a problem area, need to DIY - should be some diagrams of the area in the assembly manual
Thanks again RED58, Shouldn't be to hard to make the bends....
