3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#233340 05/06/2007 1:19 AM
I have a 51 Chevy 3100 with the original steering column that I need a smaller steering wheel for. It now has power steering and a few other mods and I want to stay with a Chevy wheel of some kind, 14" or 15" preferably with the Chevrolet or bowtie logo in it like out of a Camaro or Chevelle. What I do not know is how long Chevy used that same size shaft and spline. I have found a couple of early Camaro wheels that look, in the pictures, like they might mount on my column but I really can't tell. Anybody have any ideas or maybe even a wheel? thanks!! slowgoer
54 Chevy 5 window - 46 Chevy 1/2 ton
#233341 05/06/2007 1:24 AM
Leo Offline
Moderator
Moderator
When I bought my 69 chevelle, it had an early 70's steering wheel out of a camaro. I took it out and its available. It does not have a bowtie emblem but SS in the centre. It is in excellent condition and is black.
#233342 05/06/2007 1:29 AM
1953panel; Will it fit my 51 column? If so, how much with shipping to Georgia 30701? thanks! slowgoer
#233343 05/06/2007 1:37 AM
Shaft size and splines are the same up to at least the late '80s.
Question-Are you still running manual steering, or have you converted to power? If it's still going to be manual, you may want to rethink the smaller steering wheel.
Bill Burmeister
#233344 05/06/2007 1:40 AM
It now has power steering but with the original column which is the main reason for the smaller wheel, as you know you have to have the big wheel for manual but it doesn't work well with power. slowgoer
#233345 05/06/2007 1:45 AM
Bill; So if I find a GM wheel(Camaro, Chevelle or whatever) that is any age up to the early 80s I should have no problem attaching to the 51 column??
#233346 05/06/2007 1:53 AM
Should be fine.
Bill Burmeister
#233347 05/06/2007 1:57 AM
The Camaro wheel has a dish to it so with a stock column it may be a little too high since the stock wheel is flat. I used one off of a Fiero, it's flat, 3 spoke, and looks like a small version of the original wheel on my 56. I also used the center cap from a mid 70's Camaro with the bowtie logo.
Fred
#233348 05/06/2007 2:32 AM
Fred, What year was that Fiero. I definitely want a flat wheel also what was the year on the Camaro cap that fit the Fiero wheel? Did they fit the old column without any modification? Unless I hear something better, I think I will try to find that same set-up.
#233349 05/06/2007 2:43 AM
You may want to think about cutting the column shorter too. I took 4" off mine and with the smaller wheel,it makes a BIG difference.
Marty
#233350 05/06/2007 2:48 AM
The column does need to be shorter. How much trouble was it to cut it down? mitchell
#233351 05/06/2007 4:46 PM
I'm not sure of the year of the Fiero, one model had a longer hub. There seems to be plenty of them in the wrecking yards. The spline on the shaft is the same so it is a bolt on. The center cap is from any 70's Camaro ralley wheel also the same on Chevettes. I haven't figured how to post to this site yet but if you send me a email I can send you a picture.
Fred
#233352 05/06/2007 7:01 PM
You say you have power steering and the original column. Therefore your column has already been cut, to remove it from the original steering box. To make it even shorter it is as simple as trimming more off the bottom end and sliding it farther down in the dash clamp.
What I don't know is how the 3 speed shift linkage works if you do this.
I added power steering to my 52 and used the original column, but I left it at the stock length in the cab. I also use the stock wheel, and have no complaints or problems with it. I see no reason for a smaller wheel unless you don't fit in the truck with a large one. I can turn mine sitting still with one finger resting on the rim of the wheel, it's nice.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#233353 05/06/2007 10:15 PM
I bought this truck as a work in progress. Someone else had already shortened the column. It also has a 350 with auto so no linkage concerns on this one. The stock wheel works fine except the ratio is quite different with a big wheel and power steering. The smaller wheel would make driving a little more "normal". If the shaft was shorter I wouldn't be as concerned about finding a flat wheel, I could use a dish type with no problem. mitchell
#233354 05/06/2007 11:47 PM
In a sense,the dish type with a shorter column would be safter too- With the column further away there is less chance of getting impaled in a collision.
#233355 05/07/2007 12:47 AM
Not to divert the theme of this thread, but I am considering converting to power steering so I interested in what is the best manner to go about it? Also, it sounds like if I am to change wheels I would want to do that prior to cutting the shaft? Thanks for the help.
