2 members (Scott '48 2ton, dgrinnan), 141 guests, and 2 robots.
Topics128,163
Posts1,056,962
Members48,458
#233331 08/08/2007 2:48 PM
Junior Member
Junior Member
I know the VIN tag is supposed to be on the driver side door post between the two door hinges (a bit closer to the bottom hinge). My problem is that it's not there. It doesn't even have the rivet holes at all. Is there some other place that the VIN will be on the P/U? I know what the actual VIN is based on the registration, but I'm looking for someplace on the truck itself. I know that some of the earlier trucks only had the VIN tag and a serial # on the engine, but I'm not certain if the 1951 fits into this category. Would there be a stamp on the frame somewhere?
Ohayden
53 Chevy Coupe (Daily Driver)
67 Chevy Camaro (Toy)
68 Chevy Camaro (Weekend Driver)
It won't have a tag anywhere else besides the body serial number tag on the left door post.
You can buy a new tag and stamp the serial number on it.
Steve
'49 3800
'52 3600
'57 3100
Junior Member
Junior Member
Where would I be able to buy a new tag? I've looked and haven't really found anywhere to do so.
Ohayden
Check with Jim Carter's or one of the other vendors for Advance Design trucks.
Steve
'49 3800
'52 3600
'57 3100
8
Junior Member
Junior Member
8 Offline
when you go to register the truck, the dmv here in vermont "issued" me a stick on VIN tag which had to be applied in the presewnce of a state inspection station dude... i didn't have one either.... now i have shiny new one.
