| | | Forums66 Topics128,164 Posts1,056,965 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 21 Junior Member | | Junior Member Joined: Sep 2002 Posts: 21 | I know the VIN tag is supposed to be on the driver side door post between the two door hinges (a bit closer to the bottom hinge). My problem is that it's not there. It doesn't even have the rivet holes at all. Is there some other place that the VIN will be on the P/U? I know what the actual VIN is based on the registration, but I'm looking for someplace on the truck itself. I know that some of the earlier trucks only had the VIN tag and a serial # on the engine, but I'm not certain if the 1951 fits into this category. Would there be a stamp on the frame somewhere?
Ohayden -------------------------------- 53 Chevy Coupe (Daily Driver) 67 Chevy Camaro (Toy) 68 Chevy Camaro (Weekend Driver)
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | It won't have a tag anywhere else besides the body serial number tag on the left door post. You can buy a new tag and stamp the serial number on it. | | | | | Joined: Sep 2002 Posts: 21 Junior Member | | Junior Member Joined: Sep 2002 Posts: 21 | Where would I be able to buy a new tag? I've looked and haven't really found anywhere to do so.
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Check with Jim Carter's or one of the other vendors for Advance Design trucks. | | | | | Joined: Jul 2007 Posts: 24 Junior Member | | Junior Member Joined: Jul 2007 Posts: 24 | when you go to register the truck, the dmv here in vermont "issued" me a stick on VIN tag which had to be applied in the presewnce of a state inspection station dude... i didn't have one either.... now i have shiny new one. | | |
