| | | Forums66 Topics128,065 Posts1,055,865 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | When I was younger I was at a friends house and his dad was using a long strip of cloth, I think he said embry cloth, to polish a crankshaft. He wrapped it around once, set it on the floor and started pulling back-and-forth on the cloth strip. He said it's the poor mans polishing job. My question is, what was the cloth, have you ever done it, and can I do it on my spindles to get rid of light rust, and scratches? Thanks. Michael | | | | | Joined: May 2005 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 44 | emery cloth -- bought in strips at some auto parts stores...yes you can do it !
Hello, Welcome to America press '1' for English Puess '2' to disconnect until you learn to speak English
| | | | | Joined: Jul 2005 Posts: 8 Junior Member | | Junior Member Joined: Jul 2005 Posts: 8 | I used it on spindles on my Pontiac after the wheel bearing seized. Worked like a charm.
Never read the small print...There is no way you're gonna like it!
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Does it come in different course grades like sandpaper? And if so, what grade do you use? Thanks for the info. I thought the guy was nuts at the time and 20 years later I'm going to do what he did. Ha life is funny. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | jomichael,
I think something like 320 would be a perfect grit to polish with. Just don't go nuts where the bearing race seats..this ideally should be a tap fit and the OD shouldn't be reduced. I will bet your friends dad was using Crocus cloth to polish the crank.
Stuart | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | atomarc I wanted to get rid of some light rust and streaks right where the bearing race seats, so would you still recommend 320? I too do not want to reduce the OD too much. Should I even attempt it? Crocus cloth, might I find that at an auto parts store? Is it similar to emery cloth? Thanks for the feedback! | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | jomichael,
If the light rust is cosmetic, could you just wire brush it well and call good. If it affects the way the bearing seats a light polishing would the the ticket. Crocus cloth is very fine and only good for true polishing...it won't remove much material. I think a hardware store would have Crocus cloth...feel it with your fingers and decide if you need something that fine.
Stuart | | | | | Joined: Mar 2006 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 89 | jomichael, I am a gunsmith and polish things all the time. Don't worry about reducing the OD with 320 or 400 cloth. You'll be able to a get a finish that is plenty nice for wheel bearings. You won't even be able to tell with an analog mic. Good Luck.
240,000 worker bees! 1960 Two ton Chevy
| | | | | Joined: Jan 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 63 | Emery cloth can be purchased in a roll or sheet. I think 3m is the best known maker. Try this site http://shorinternational.com/Emery.htm . Emery cloth/paper with a penetrant oil of some sort to "wet sand" it will clean your spindles easily. But I would start with a finer grit than 320. personally I would go with 600. I used to use it on piston pins.
1941 AK named "PETEY" my buddy.
