3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#23311 06/22/2004 3:40 PM
Pal
Offline
Has anyone ever heard of installing a hand clutch on a 4 spd?
Reason: Knee problems, unlikely to be fixed. It's either a hand clutch, tranny swap to an automatic (yuk), or sell the 68. (wifey votes for #3)
35 + years of rollin' steel!
#23312 06/22/2004 3:49 PM
they are used in dirt track raceing, I will check with my son to see how they are set up, Popcorn may also be familar with them since he is on the race scene,,,regards,,Fred
Redryder pix
My Hotrod
#23313 06/22/2004 5:01 PM
H Online: Content
I've helped set up hand-control cars for paraplegics a few times. You'll need to look into the correct leverage on a hand control to allow you to depress the clutch effectively, and hold it down without undue fatigue at a stoplight, etc. "Heim" joints, those ball-type parts with a bolt through the center, work pretty well for the ends of the pushrod, and you'll need a long bar mounted to the dash with good mechanical advantage for a control lever. It would also be possible to use a vacuum-assist like a power brake booster to lower the clutch pedal effort, with a little creative engineering.
#23314 06/22/2004 5:20 PM
Jerry: years ago and I mean years ago, they had either vacume assit or something compatable when guys started using huge pressure plates in drag racing. Can't remember the actual process but it helped with pushing in the clutch. You are very correct by telling Pal about Handicap Driving there is some wonderful products on market to help these people.
Fred: Our dirt track car is now converted over to power glide all we need is to go fast and then slow down. Fast, slow, 4 times then be in front. grin popcorn The Truth is Out There (Good luck Pal and automatic not that bad)
#23315 06/22/2004 6:26 PM
I think a hydraulic action is the simpliest solution.Master cylinder with a lever, easy the run the hose to a slave cylinder on the clutch housing.Racing suppliers like Summit or Jegs should have the necessary items, just have to fabricate a few brackets.
#23316 06/22/2004 8:08 PM
If you can't push the clutch properly do you feel safe operating the brakes in an emergency on an old truck? I would go automatic and concentrate on braking.
54 3100 with 235
62 flatbed dump C60 with 261
#23317 06/22/2004 8:28 PM
Pal
Offline
Thanks guys. Good Ideas and I'll take any you've got.
Tony: The right leg (brakes) is fine. It's the left that's heading south.
Popcorn: Automatics are ok, but that's not why I bought and built this old girl. She drives (whines and rattles) just like my Dad's. I'm sure you can understand that. Changing her to an auto would take away alot of that old flavor. I'd rather make someone else happy than that.
#23318 06/22/2004 8:33 PM
You should be able to use a hydraulic clutch with a vacuum boosted brake master cylinder with a bit of fabrication.
Paint & Body Shop moderator
#23319 06/22/2004 9:41 PM
A mechanical linkage with a lever up thru the floor on the driver's left connected to the existing clutch pedal/linkage should not be too hard to figure. Another obstacle in the way getting in and out, but simple. They had them in Model T's for nearly 20 years. One safety concern would be both hands off the wheel briefly while you shift....I hope you get it worked out and let us know how you did it.
Professional Novice
