4 members (Hotrod Lincoln, Southerntruck, Rich'sToys, 1 invisible), 83 guests, and 3 robots.
Topics128,090
Posts1,056,373
Members48,442
I have a 51 3100 Chevy with the stock 16" 6 bolt rims. I am contemplating swapping these out for newer style rims. Can someone provide info on what newer year rims will fit my truck without the use of a hub/stud adapter?
I prefer to stick with 16" (so they do not look small in the wheel well)but may go to a 15" with a bigger profile set of rubber to compensate for the reduction in rim diameter.
Thanks in advance.
Best Regards
Will
The six lug chevy truck ralley wheels from the 70's and 80's will work on these trucks.On a side note if you do go that route do you want to sell the original wheels?
thanks for the info
I will not be selling the original rims however
Best Regards
Will
