1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23080 03/11/2003 8:04 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Just got a note from Jim Carter advising that they have developed a manifold preheater setup that works around problems that many of us have had for a long time. Most try to use the coolant to pre-heat the intake but this uses exhaust gases to do it which to me makes a lot more sense. Here's what I got in the mail: Fenton Header Upgrade for GMC Engines (and you Chebby guys too!) | | |
#23081 03/11/2003 9:03 PM | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | Interesting. Looks identical to the ones which some guy used to sell on the internet (e-bay). Maybe making them for Carter now. Only thing which concerned me about those was constant heat whether needed or not. Get the carb too hot in the summer? Would like to hear from anyone using them.
Buzz'n Half Dozen
#23082 03/11/2003 10:36 PM | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | It sure looks like Stovebolt Engine's heater plate. Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
#23083 03/12/2003 5:05 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, it is like the plate from Stovebolt (Tom Langdon). I have one. The plate on eBay was machined differently.
I use water with mine because it circulates throughout an Offenhauser intake and the intake will never get hotter than the coolant temperature.
It seems to me that by using exhaust air the heat transfers by diffusion and not by circulation. Don't know if that is good or bad or neutral. The hot-air hookup sure looks nicer and is easier than running hoses to the water pump and/or thermostat housing.
There was a comprehensive discussion on heated air vs coolant in this forum during this past year.
Tim | | |
#23084 03/12/2003 5:19 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Humm, that looks a whole lot like the one I built myself, easy to do, works fine and cost a whole lot less then 48 bucks. The onle problem I had was getting clearence between the Fenton header and the offy intake. A little work with the grinder and it was done. I'd say build it your self and sove some money. Just my $0.02 George | | |
#23085 03/12/2003 6:05 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 46forme,
Did you heat with water or air?
Thanks, Tim | | |
#23086 03/13/2003 1:59 AM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | tcleaderman: I used air. Out here in sunny Ca it doesn't much matter. Back where it gets real cold water might work a little better better. Using the exhaust looks better IMHO. | | |
