| | | Forums66 Topics128,140 Posts1,056,774 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Wondering if anyone can suggest the best plsce to buy new front wheel bearings for my 55.2 1/2 ton? I'd prefer the newer tapered roller bearings. Thanks, Matt | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you prefer the roller bearings you're best off to get them from one of the repro vendors, prolly the cheapest would be the same as more expensive ... but there's really no reason to not use the OEM ball type, unless you're doing disc brakes, and those are available from NAPA and such locally
Bill | | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | Try Truck and Car Shop. The consistently have best pricing on many items.
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
