2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#228985 03/08/2007 3:08 PM
Junior Member
Junior Member
Listed below is the identification from my Protector plate. I have identified some of what the coding means, however, some of it still remains a mystery. It reads as follows:
05
CS148B143888
F0613PF
HA0613K
S8H11
Can anyone ID:
05=? R=? HA0613K=? 6=? S8H11=?
Larry Hull
Ottawa, Canada.
None
Most of your questions are probably answered in the restoration pack for your vehicle.
Here's how to get yours.
http://www.stovebolt.com/techtips/GMRestoPak.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
Junior Member
Junior Member
Randy, I received my package from Chevrolet, but it does not give this information.
Larry Hull
None
I'm not sure if your truck plate is similar in layout to the passenger car protect o plates. You will be able to judge.
Here is an example of a 1968 Camaro plate with an explanation of the various numbers.
http://www.holisticpage.com/camaro/parts/68protec.htm
Apparently the answers to interpreting your plate are found in various GM service manuals, assembly manuals or bulletins used for your truck. You probably know that there are a number of vendors who sell reproduction manuals for your truck year.
If you're ok with other people's best guesses, here's mine.
05 don't know
R Carb source, I believe. Rochester
HA0613K is the original rear axle ID code.
HA 3.73 Rear end
06 June
13 day of month
K McKinnon Industries
6 not sure
S8H11 is the original transmission ID code
S possibly Saginaw 3 speed
8 1968
H June
11 day of month
This site has tips for identifying chevy manual transmissions.
http://www.nastyz28.com/chevy-manual-transmission-identification.php
I'm not endorsing this vendor but here are several books that you may decide to purchase or borrow to help decode your plate. (I don't own any of them nor do I have a relationship with the vendor)
http://www.themotorbookstore.com/gemoprdegu19.html
http://www.themotorbookstore.com/capacaofchtr.html
http://www.themotorbookstore.com/67chevytruck.html
Junior Member
Junior Member
Once again thank you Randy, this gets 99% of it. The numbers you have given me match the Carburetor, Transmission and Rear End. If I can't identify the remaining two letters, i'll go ahead and purchase the de-coder book with the information that you provided.
Larry
None
