| | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 27 Apprentice | | Apprentice Joined: Mar 2007 Posts: 27 | Is the oil pickup interchangeable between a 250 and a 292? Are these available from any of the reproduction vendors? Thanks. | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | The oil pickup and the pan work together, the 250 units will work on a 292 but must both be used together. | | | | | Joined: Mar 2007 Posts: 27 Apprentice | | Apprentice Joined: Mar 2007 Posts: 27 | Thanks. I believe I have located a 292 pan but how do I tell for sure? Also, when my 292 engine arrived from the rebuilder, the two-sided main bearing bolt that you clamp the oil pickup to, is screwed in at the number three main. Is this a mistake? Because I thought I remember on 250's it was located at the number two main. | | | | | Joined: Mar 2007 Posts: 27 Apprentice | | Apprentice Joined: Mar 2007 Posts: 27 | How can you tell the difference between oil pans for a 292 and a 230/250? | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i think the 292 is a 6 qt and deeper. and not all the attachments for the oil pickup are the same even for the 292. the older blocks i've seen sometimes have a different main bolt that it attaches to, so the part that goes around the tube can be longer or shorter. the 292 i'm doing right now is a 64 or 65 and i had to reuse a clamp part off a old tube to make it work, the one that came with the tube was not right lenth. | | |
