1 members (1 invisible),
107
Mod | | | Forums66 Topics128,159 Posts1,056,900 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | After searching the forum I understand there are rebuild kits for the ball joint style tie rod ends. Who sells these rebuild kits? I have found any sites that show them(just LMC and NAPA so far) If any one knows I would greatly appreciate it!
58' 3200 235 3-speed/OD
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just about all of the parts suppliers have them. Personally, I didn't have to do mine. They just simply needed adjusted. You will need a drag link socket to service them. This looks basicly like a very large screwdriver bit, usually 3/8 or 1/2 inch drive. The kits consists of a new ball stud, 2 seats, a new sping, and a cotter pin. Follow the instructions in the manual to get the proper pre-load on the lie rod. If you don't get it correct, you will wear the tires with toe-out wear.
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | CPP sells them. $35.00/kit for both sides. | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Hey, Apache,
I thought I'd warn you about using those cross-steering connecting rods with the later-model tie-rod ends. I purchased one of them, and had to press out the material in the spindle arms to insert them. What I learned is this: The steel in my new cross-steering rod was super hard - way too hard for this particular component - probably up around Rockwell C-70 or higher. The harder steel gets, the more brittle it becomes. Eventually, it gets like a file, which if bent at room temperature 'snaps' rather than bends. And that's exactly what mine did - snapped like a twig rather than bend ever-so-slightly. I don't think anyone wants a safety-oriented component that shatters if struck by a large rock or something. Stick with mild steel rods for this purpose. I ended up ordering a piece of 1" mild steel to replace that super-hard rod.
Good luck! | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Thanks every one thats a big help! I decided to rebuild my front end after the bearings went out. Its just time for every thing to be restored of or replaced! Thanks again everyone! I love this site!
