ok, so i picked up a '50 3600, pretty much all original exept for 12v conversion. the main selling point for me was the sheet metal, which is in GREAT condition,(only 1 cab corner, the cab floor, and the bed/stakes are crappy.)
what i ulitimately want: sweet daily highway driver, not a full resto/rod.
- lower gearing on rear end (for highway)
- S10 5spead manual tranny (if needed for highway)
- some sort of upgraded suspension
- upgraded brakes
- she needs a new wiring harness.
i wanted to start with a disc brake conversion, but found out my 3/4 ton 8 lug wheel/axle setup wont allow it without major work. this sad news from a reliable brake/axle hot rod shop.
so it got me thinking, should i just hand this baby off, get my dollars back, or charge ahead?
i figure maybe i could find another that someone else has already mod'ed up? maybe they put in a 350ci, auto trans, discs, camero/S10/nova front end, etc? even if the body is crap?
or do i keep what i got, do a powered/drilled/vented drum brake setup, forgo the suspension upgrade, and then tackle gearing/tranny/electrical?
given that i want a highway driver, but not necesarily a resto rod, i guess what i am asking boils down to this:
is it better to start farther away from my goals mechanically with a beautiful body, or start with a better mechanical set up and a body which may need more work?
